OctaneRender™ for Blender 2.21.1 - 7.5 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed nodegraph bug affected some nodes interconnections (thanks MattRM).
  • Fixed the emission nodes inconsistency.
Blender Octane Edition - 7.5 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.5 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.5 (9.0MB autoinstaller file)
MattRM
Hi JimStar,
The emissive texture node works well now ;) Thanks.
I tried to put an IES, but in standalone, I use a greyscale texture for that, here, tried all texture node, and the plugins not list ies files like in standalone.
Did something wrong or something weird ?
Matt
JimStar
MattRM wrote:Did something wrong or something weird ?
Yes.
Just disable the extensions filter in Blender file dialog.
MattRM
Thanks ;)
Marten74
Hello!
Could any one give me a tip on how the render pass motion vector works in the plugin. If it is implemented? I can only find it in the stand alone.
I exported an animation to Octane stand alone, but the animation of the camera did not transfer. Did I miss a setting some where, or is this an issue?
::mb
Marten74
Hello again,
Just noticed something strange. I was just posting a question about this when I figured it out. How ever I was setting the render and preview samples, it only rendered 128 samples. Now I realized that it is the max samples setting under motion blur that controls both render and preview quality. The funny thing is that it does not matter if motion blur is enabled or not...
A little bug perhaps?
::mb
amadinam
Normals inside-outside light.
Normals outside-light inside.
3d max,Standalone in all good. Normal outside-light outside.
Saramary
amadinam,
I've read your post 3 times but still cannot understand you and your problem. :?
Try to explain it a little bit clearer and we'd happy to help you.:)
Win 8.1 x64, i7-4930K 64GB, 2 x GTX-690
amadinam
1) Create a sphere
2) visible normals
3) apply the material emission
= down Light
4) flip normals = light up
pegot
I'm not entirely sure what your question is either amadinam. Are you saying that even though your normals are flipped, light is still escaping the emission object instead of being contained inside it? If that's your issue, I think it's because you have set your emission object to fully transparent (your opacity setting is 0).
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Return to “Blender”
