Glass Test
Tugpsx
Thanks a million.
Are these the correct settings?
yzaroui
Yes!
The index for refraction is 1.52.
The filmindex is ignored since there is no filmwidth.
radiance
yzaroui wrote:Yes!
you also need to set the reflection higher...
both reflection and transmission should be 0.9 or so...
Radiance
yzaroui
That depends on how much transparent do you want the glass to be.
The more the transmission values are high the more the glass is transparent (and of course less coloured).
arian.mares
Hi!
I just realized that Octane can't project colored light that's been filtered by colored glass when using the daylight environment.
In an architectural scene where I'm using colorful stripes of glass, the daylight that passes through that glass should be projected on the objects behind with the specific color of the glass that acts like a filter retaining all the wave lengths of the white light but the one corresponding to the filter's color. Well, the rendering engine apparently can't do that.
The rendering attached was made with a different software.
arian.mares
Does anybody know a solution to this issue?
kubo
yeap use an HDRI, since sun doesn't go thru transparent materials yet, for it to work there is an small workaround, lowering the glass opacity to use along with the sun system.
arian.mares
Thank you!
