Strange Multi GPU issue
- scarecrow2k6
I'm having the exact same problem as Mojo. Although tested with one Gtx 470 and one Gtx 285 but I think its the same issue.
I have the same Problems too, got anybody a solution???scarecrow2k6 wrote:I'm having the exact same problem as Mojo. Although tested with one Gtx 470 and one Gtx 285 but I think its the same issue.
win7pro|core I7 960|6gb Corsair XMS3|AsusP6X58DPrem|1000W BeQuietP8|PNY GTX470|PNY GTX480|LianLi Tyr500B
Hi guys,
I'd recommend to check your nvidia control panel settings and make sure SLI is off, remove any SLI bridge connectors and enable physx.
We're changing a few things in the upcoming 2.3 version which should make solve these issues.
Radiance
Radiance
[quote="radiance"]Hi guys,
Radiance[/quote
thats it, got it now, installed octane b2.2, the latest nvidia drivers and the cuda toolkit, the sli bridge i had removed sometimes before, enabled physx and now I`m enjoying about the heat coming out of my system, produced by two running GTX Cards
The temperature is insane, think about to install additional fans, even the wooden floor behind the case is in a range of 20 cm really hot, unbelievable.
With the b2.1 release I had to disable physx to see the second card, but yesterday I detected that the two cards together running got the same speed than only one card, after radiance advice the problem had been solved.
Thank you Radiance!!!
It´s really impressive how much patience you got to solve any problems of the octane users. Never got such a support, post a question an just get an answer, GREAT!!! Hope you and your Team get the success you deserve.
Best regards
MrMouche
Radiance[/quote
Best regards
MrMouche
- mojo_jojo_mark
Sounds like its defo a pre fermi related issue as radiance had mentioned before. I've tried everything with no luck
win7 Ult x64, Q6600 3.2, Asus p5n-d, 4gb, 2x GTX 280, 900w PSU
Similar multi-GPU issue. I can't get Octane to use all three GPUs.
Here's another data point:
I am on the bleeding edge and running CUDA 3.1b, Driver 257.19.
I have 3 cards: 2 x GT240's with monitors connected. 1 GTX 470 without a monitor.
All 3 cards are recognized by Octane and I am able to assign them as "Active".
But as soon as I start rendering or restart Octane, I'm back to a single GPU (a single GT 240) in the Active list and the other two cards are Inactive.
Otherwise, I'm psyched to see how 3 GPUs are going to perform!
[Edit: I'm running Win7 x64 ]
Win7/x64 | 2xGT240 + 1xGTX470 | Foxconn ELA
For the demo version (2.2) you might want to try with some older drivers as it's built against cuda 3.0 and older drivers,
just install the same ones we recommend in the installation video, which you can find on the downloads page.
Radiance
Radiance
