Instead all i can do is 30cm high with 250 DPI and this is only the raw render which i can not do any crap with.
So i have told about the here and i was told the vram is limited by my gpu ( which is a gtx 780 - 3gb) So i said if i get a 2nd card would it solve my problems?
The answer was "maybe"...
I will eventually get a second card because the c4d itsself needs gpu to show you your polygons and etc. But
1) should it be a 3gb higher? like titan?
2) i know that if you have a higher card the psi system will be dependant on the lower speeded card... meaning yo shoul always double with the same card.
3) this may be a out-of-subject question I NEED MY LIGHTS SEPERATE like vray and maxwell. Now, i know you guys are working really hard... so just tell me if i need to learn how to use the standalone, or upgrade to 2.20 (which i think is not ready as it say "candidate" ) or what
thank you for your time. Anybody please answer, i have a project due monday and i can get my passes rendered in 16bit 300dpi...
