Rotate HDRI inside 3ds Max for octane?
cgpanda
I just tested Demo, i can't seem to rotate hdri map like i can in stand alone version. Is this correct?
Thanks in advance
glimpse
Hi, Panda, You can.. =) but I'm not at PC to say for sure witch parameter - go through every piece & You'll find it =)
Dom74
Use 2D transform in bitmap, and translation.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
cgpanda
I had to first use "Texture Environment" then put image inside it. This way i seems to be able to rotate it.
Previously i directly put image texture without "texture environment".
Thanks for the help
Return to “Autodesk 3Ds Max”
