Version 2.20.0 RC2 - Release candicate 2
valters
aoktar wrote:
LSDI wrote:Hi Aoktar
I installed the rc 2.20 on c4d r13, livewer operates normally, but after running "render to picture viewer", and stop it, i can't launch liveviewer, i need to stop and restart c4d.
Do you know this pb?
Pascal
cinema 4d 13
3 gtx titan black
3 gtx titan
can't see same behaviour. Can you check it for a different scene to see same again?
I Don't know if this is the same problem but I have asked a couple versions before to fix "this" problem with no luck. I don't need to restart Cinema 4D. My problem is if I run Live Viewer and then stop it, button to start render again not works and I need to close all panels with Octane and open again from main menu. AMAZINGLY!! Annoying!!! but I didn't get answer when this will be fixed.
http://render.otoy.com/forum/viewtopic. ... 34#p213834
I'll put a test version here soon. Can some test it for this problems?
LSDI
i use liveviewer only and it's ok
LSDI wrote:i use liveviewer only and it's ok
I think that i found the problem. I'm going to put a version in a few min.
This is the RC2 version. Before releasing it need some checking. Thanks
Windows only:
http://render.otoy.com/customerdownload ... C2-win.zip
valters
aoktar wrote:This is the RC2 version. Before releasing it need some checking. Thanks
Windows only:
Thanks. From my side problem with "stop LV >> run again not working" is still here. So I need to close LV, go to main c4d top menu where file/edit/create/select... [octane] /help and open LV from there. Then again I can run octane for once until first stop.
+ I don't know what it is and is it me or Octane...
banding
banding
Valter,
Please don't use icons from both window. Just use on set and disable other. What are you asking for exactly?
valters
aoktar wrote:Valter,
"What are you asking for exactly?"
Just to check my PNG that explains that if to turn on MP than Main image have color issues (banding) as on png i showed.
"Please don't use icons from both window."
Can you please provide me instructions on how to use Octane Render Live View to Start/Stop/Start.
All I want is that forget about this problem. I do this annoying ..**.. over months since 2.12.2 update.
use dithering for 8bit or use 16-32 bit images. Otherwise it's a display problem for your host program.
If you are using octane dialog+LV, close button's of LV. Just use octane dialog to control render. OR don't use octane dialog. Can you imagine how much big implementations is done here since 2.12? "Anoying words" makes me "uncommitted" to be eager for adding the new features. There is many versions to stay with them until things are being stabile enough.
Sorry
valters
Sorry
"use dithering for 8bit or use 16-32 bit images."
I use only 16bit png or 32 exr
"Just use octane dialog to control render"
Tried 100times but will try again
""Anoying words" makes me "uncommitted" to be eager for adding the new features. "
Thats Ok. From the beginning as I started to be licensed user I was trying to sent any bug reports immediately and in details. When my Octane got this bug on 2.12 I made immediately this report and one other guy also reported this..on 2.14 I repeated this report... I hope in version 3.0 this will be fixed.and of course its annoying....when if you want to start engine of the car, before this you need to go out, close it and sit back again
collection for history
Return to “Releases”
