OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for ArchiCAD STABLE RELEASE.
ArchiCAD Version
This version of the plugin runs on ArchiCAD 17, 18 and 19 - 64 bit Windows (Vista, 7, 8 and 10).
Nvidia Driver Version
This release requires Nvidia drivers 353.x or later.
Network Rendering
For Network Rendering, you must use the Octane slave release 3.02.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- ArchiCAD version (ArchiCAD -> Help -> License Information -> Version and Build Number
- OctaneRender for ArchiCAD version (ie. 1.02a)
- In the unlikely event of a crash, pls provide the dump report from the C:\Users\[username]\Graphisoft\BugReporting-[version] folder (on Win 7). Either post or email (to "paul at physicalc-software.com") the "ArchiCAD-XXXXXX-FATAL.RPT" file from this folder.
For more information...
- Check the specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/ArchiCAD/?page_id=353
- Read the on-line manual
- Read the FAQ
- Watch Tapperworks Showcase Part 1, Part 2 and Part 3
- Watch Tapperworks Render Passes video http://youtu.be/sXnLcWEbbmY
- Watch the Grass Generation video http://vimeo.com/113454418
- Check the Facebook page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for ArchiCAD 19 3.4.0.66 (64 bit)
- OctaneRender for ArchiCAD 18 3.4.0.66 (64 bit)
- OctaneRender for ArchiCAD 17 3.4.0.66 (64 bit)
Previous version:
- OctaneRender for ArchiCAD 19 3.3.2.64 (64 bit)
- OctaneRender for ArchiCAD 18 3.3.2.64 (64 bit)
- OctaneRender for ArchiCAD 17 3.3.2.64 (64 bit)
Release Notes
Refer to the TEST release thread for release notes.
Release notes for 2.20.0.36 are:
2.20.0.36
- Fixed issue when input from the LocalDb was not working for materials downloaded from the LiveDb
- Compiled with Octane 2.20 (see Octane Standalone for details)
- Added Polygon Side texture node (see Octane Standalone 2.14 release notes for details)
- Fixed issue were Save As Default was not working
- Any embedded texturemap files found when importing an ORBX will now be extracted into the LiveDb texturemap folder
I have held off increasing the texturemap name length from 50 for the moment, since it relies on changing the format of the "default material" files, and some irregularities with this approach have been uncovered on one of the other plugins, so I want to get it working flawlessly before implementing this in the AC plugin.
2.20.0.37
- Fixed bug where AC would crash when opening the plugin if there was an invalid AC material used in the scene
marek
Paul[/quote]
face_off wrote:I have refreshed the installers at the top of this thread with:
2.20.0.37
Paul,
Thanks a million!
Just one hour was enough for you to fix that!
All is fine now.
Cheers,
Marek
marek
Paul,
I've happened to notice one thing.
Tried to assign a grass material from DB, called Grass with flowers to my AC texture and experienced a black screen and then NVIDIA Open GL Driver error window as attached.
Archicad was closed but didn't generate a bug window as usual only a RPT file, not able to attach here.
Other DB materials work OK, so I didn't bother to search Nvidia site for that issue.
The message below says that "Driver stopped responding and has recovered".
Marek
Hi Marek. That material has displacement - which I suspect if causing your video drivers to timeout (see question 4 at http://render.otoy.com/manuals/ArchiCAD/?page_id=274), since that LiveDb material worked OK for me. If you install Octane Standalone 2.16 from http://render.otoy.com/forum/viewtopic.php?f=24&t=44074 it should make the appropriate registry setting changes to fix this.
marek
Hi Paul,
I've got already Octane Standalone Edition version 2.20 installed.
Should I downgrade it to v.2.16?
Marek
You need to run any Octane Standalone installer. It's the installer which updates the registry settings. If you installed from the ZIP archive that doesn't happen - you need to run the installer EXE.
marek
My installation file: OctaneRender_2_20_win64.exe.
Marek
OK. You'll need to do some experimenting then if you want to use that Liveb material. Try applying to an empty scene with a single slab and opening the Viewport. You could also try setting the displacement amount to 0.00001 and open the Viewport. Your graphics card and other hardware is superior to mine, so you should be able to use that material. If all else fails, set the displacement to 0, open the Viewport, save to ORBX and send me that file (indicating the material name with the grass displacement material applied).
Return to “Graphisoft ArchiCAD”
