OctaneRender® for 3ds max® v2.20
Karba
Main changes since version 2.16a
  • Fixed low quality render element render.
  • Fixed bug where render elements render after being deleted.
  • alpha reflections. A new option in the specular material that, if enabled, will give specular materials alpha transparency if the alpha channel is enabled in the kernel settings. The way how that works is by making reflections opaque and but refractions transparent. As a consequence, absorption, SSS and coloured specular transmission are not properly rendered with this option enabled.
Due to the switch to CUDA 6.5 you will need a current graphics driver of version 344.x or higher.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... p_2_20.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=33&t=44232
At the moment there is no proper way for implementation of multi uv channels. octane standalone implementation doesn't allow to do that without extra GPU memory consumption even if it is not used.
Yours,
The OctaneRender® Team.
bcravin
Thanks Karba,
Will the new Render Layer options be implemented in 3ds Max plugin? Or, or those options already available?
vfxman83
Thanks Karba,
The new alpha reflections can convert vray 2 sided material ?
I have a problem with evermtotion trees octane couldn't read the vray 2 sided materials
Can you fix this problem ?
cybernoid
Thanks for the continued updates.
Is there anything happening regarding support for render time opensubdiv available in 3dsmax 2015 or even Turbosmooth?
_________________
RTX 3090, Ryzen 5950x, 32GB RAM, Windows 10 64-bit
wastzzz
Thank you for fixing render elements quality!
M.
[email protected]
alpha reflections! finally!! thanks otoy team!
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
Karba
bcravin wrote:Thanks Karba,
Octane render layers were designed only for compositing purposes. They work differently from 3dsmax layers. I don't see any way to get any useful usage in 3ds max.
Karba
cybernoid wrote:Thanks for the continued updates.
opensubdiv is buggy. and it works before render start, not during render time. 3dsmax turbosmooth works much better.
Karba
I will update material conversion next week.
ka-ra
Karba wrote: Octane render layers were designed only for compositing purposes. They work differently from 3dsmax layers. I don't see any way to get any useful usage in 3ds max.
So, no way to have this in 3ds max?
For example by tagging objects? like we tag them with octan properties?
Return to “Releases”
