TURNING THE VIEW IN OCTANE RENDER
Hello everybody. Sorry if my english is not perfect. I have a problem with Octane Render Stand Alone version, that I'm trying to learn: I can't turn the view in horizontal way (around a vertical axis) around the mesh I've imported, but only vertically. The manual says that is enough clicking the left mouse button and rotate on the view, but it doesn't work. I have the most recent version license of the program. Somobody could help me? Thanks.
Have you used any of the camera view presets? These will change the camera's "Up-vector" property.
The default is 0,1,0
Try putting it back to default. If it's already at default then maybe your geometry is being rotated during import or export (Up axis is not interpreted as it should be).
