OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
TRRazor
Not quite sure what is causing this, but with the new plug-in version, re-positioning the Daylight in Poser with the OR viewport open, causes Poser to freeze for a couple of secs and become inactive. After a short while the behavior goes away, only to return when you re-position the Daylight again.
EDIT: This is also the case when rendering in the viewport is paused.
EDIT 2: Only happens when you have the AutoRefresh set to "ON"
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Hi, I cannot reproduce this problem. Do you know which release of the plugin it started happening with? (ie. which release was OK, and which had the problem).
ch0pper
I have tried that Paul
does not work.
i will try and reinstall her see if that helps
(UPDATE reinstalled. still the issue is there.)
only seem to be on Genesis 2 female.
Genesis 2 male works fine
Genesis 1 base also works fine
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
Image 2 is showing the "Export All Materials For This Figure/Prop" enabled - so that appears to be working correctly.
The menu for Image 1 only has copy/paste - and you will get that menu if the material you right click is not used by any geometry in the figure.
ch0pper
nope does not work.
nope does not work.
Does it display an error? Have you checked the Octane Log for errors? Is it importing or exporting that is not working? If exporting is not working, can you send me the resulting POC file pls? Have you checked the octaneplugin.log file for error message?
ch0pper
Okay I find the bug lies,
To replicate the bug is quite simple, take a Genesis 2 female character. And make sure the viewport is open and rendering. (You cannot import while the render window is open)
if you close the render window it will let you import (so it's definitely a bug)
Also when I try to import while the render window is closed.
It simply will not take the import settings
It's quite a strange bug the Genesis male figure seems to work.
In Genesis 1 base seems to work,
The bug only seems to be related to Genesis 2 females?
#I have tried to reinstall but the bug remains
no error messages
were do the logs files live again?
also if you close the render window.
and say try make the Genesis 2 female character wood or grass from live database,
it say its done it but when you try render it, it just the same as default.
TRRazor
Hey Paul,
I restarted both, Poser and Octane, and the problem went away.
So all good for now :)
ch0pper
Any information on this bug Paul? Usually quite fast reply
I'm guessing your off on holiday or annual leave something anyway
it's not 100% critical but get back to me when you can if possible please
wimvdb
ch0pper wrote:Any information on this bug Paul? Usually quite fast reply
I was unable to reproduce the problem. I followed your steps and everything works fine
I may have an older version of the dson importer (i use 1.1.2.117). Tried it with Poser Gamedev sr 5.1
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Return to “Poser”
