OctaneRender for Carrara 2.16.0064 [Release Candidate]
Carrara (Integrated Plugin developed by Sighman)
Sighman
WARNING: This version has had limited testing. Use at your own risk!
Changes in 2.16.0064
  • Added Clay Mode support.
  • Fixed saving/loading of Highlight compression Imager setting.
  • Fixed Render Lock.
Changes in 2.16.0063
  • Fixed a problem where changes to render target settings caused the environment to get re-evaluated. When environment overrides are used this caused the render to restart.
Changes in 2.16.0062
  • Fixed problem with replicator visibility.
Changes in 2.16.0061
  • Fixed problem with animating materials.
Changes in 2.16.0060
  • Added network rendering support.
  • Added render region support.
  • Fixed issue with visibility/object layer animation.
  • Fixed crash when closing viewport.
  • Updated Render Pass Export Dialog to match standalone.
  • Fixed backdrop transform when panning and zooming image.
For network rendering I strongly recommend you get it working in the standalone first and then enable it in the plugin.
Pending any issues with this release I will be marking it stable next week and generating a new Demo version.
ATTENTION: This version is based on Octane 2.16. That means you need to update your NVIDIA graphics drivers to at least version 344.x
Happy Rendering...
Download Links:
OctaneRender for Carrara (64-bit) 2.16.0064
OctaneRender for Carrara (32-bit) 2.16.0064
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
dustrider
Thanks Sighman!
Tugpsx
Thanks for update, more testing
Tugpsx
Crashed a couple of time, will try again later, after my backup jobs have finished. I assume one may have caused the crashes.
EddyMI3D
Great *thumbs up"
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
Sighman
New update posted to fix issue with animated materials.
dustrider
Thanks Sighman!
rashadcarter
Thanks for this update, Sighman. A couple of questions already
1. Where is the F-Stop control slider that used to be found under Imager?
2. Why is the default Exposure setting different? It comes in now as 0.5... but it used to be exactly 1 by default.
Back to playing now!
rashadcarter
Questions were answered. No worries. Thanks
EddyMI3D
rashadcarter wrote:Questions were answered. No worries. Thanks
And what did you get? Would you like to share?
My Rig:
Win 7-64
Nvidia GTX 760
Return to “Carrara”
