So, I just spent a lot of money today buying a license for the stand-alone version of Octane and the Daz Studio plugin.
Unfortunately, when I click the "Open Viewport" button in the DS Plugin, the viewport window opens and says "Building Geometry"...and it never finishes.
I just downloaded the latest versions. I have activated everything, according to the website; of course the plugin Activation on the "Octane" tab has a big red "X", even after I click the "Activation Manager" button and the Activation Manager says I'm registered...but that's a separate issue.
I tried running the stand-alone version of Octane Render and I have no problems. I can render to any size I want, I can save files, I can do everything (even though it seems to be a little slower than the demo version (?!?)).
What I can't do is use the plugin. Octane has no value for me if I can't use the plugin.
The plugin identifies my graphics card, GeForce GTX 745 - Compute model: 5.0
Down at the bottom, unfortunately, it also says, "10:11:32:238: Unknown Nvidia GPU model found ()".
As I said, I can run the stand-alone version of Octane just fine, so I know its not a gpu compatibility issue with Octane; and therefore will not be changing my gpu (I've already spent enough money on this). For some reason, the plug-in won't work.
Please help me with this problem as I have much work that I need to do. If this cannot be resolved, I would like a refund, ASAP.
Thank You
JM
Building Geometry - Forever (Only in plugin)
Moderator: BK
I forgot to mention, this happens no matter what is in the scene or if there is nothing in the scene.
I first tried a room with a few chairs in it. Then I started a new project with just a Genesis figure in it. Then I started a new project with nothing in it. No matter what was in the scene, "Building Geometry".
Thank You
JM
Thank You
JM
- larsmidnatt
you never mentioned which version of the plugin you were using.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
i9 10900k 64GB
2080S 8GB
More fun. Now Daz Studio won't launch without crashing right away. So, now I can't use the Octane plugin OR Daz Studio.
No, it is not a bad Daz Studio installation. I have been using it to create numerous scenes without crashing. I've installed the 1.0 version of the Octane plugin and now it crashes whenever I launch Daz.
Getting Frustrated,
JM
Getting Frustrated,
JM
Well, I found another version of the Plugin (v.2.1)...NOT the one in my "Downloads" area. The new plugin works!
I would HIGHLY recommend to Otoy that they have some option available to download the latest plugin version. I have spent the past 7 hours trying to solve problems on a plugin version that simply didn't work (v.1.2).
Is there a reason the 2.1 version was not available for me to download from my "Downloads" area?
Thank You
JM
Thank You
JM
- Spectralis
Have you tried downloading the plugin materials DB cache? This needs to be downloaded before the plugin will work properly. Follow the installation instructions in this thread:
http://render.otoy.com/forum/viewtopic.php?f=44&t=38116
This is often where new users get stumped after they think they've set everything up correctly but still haven't d/l the cache. It's not exactly an automatic or intuitive installation process yet unfortunately. The Carrara plugin uses a different system concerning materials so that step isn't necessary.this version uses a new format for the Live DB cache, means the cache will need to be filled up again. if you have a fast internet connection and like to fill it up all at once, you may do so by: open the Live DB entry in the Materials tab, click on any item in the Live DB materials list, do CTRL-A to select all and CTRL-SHIFT-M to copy them all into the current scene; this will download all thumbnails and settings into the cache.
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
