OctaneRender™ Standalone 2.15
gardeler
Yeah, the res is pretty high, 30", 2560 x 1600, but that should not steal 3 GB ram, right?
grimm
You can find out how much memory is being used by the system with the Nvidia settings tool. I use Linux so I don't know what it's called in Windows. This is also might be affected by other programs currently running that use vram as well. For example if I run 3D-Coat and have a large voxel object that I'm working on my vram usage will balloon up to over a Gbyte. If I include my 460 in a Octane render my 980 would look like it had only 800 MBytes of memory. :D Octane always uses the smallest GPU memory as the amount of free vram that it has available.
roeland
Disable SLI / Multi-GPU in the NVIDIA control panel. You often see extra memory usage like this when it's enabled.
Roeland
gardeler
Darn! You beat me too it! I just found out as well, it did the trick! (it is funny that the tick box says "disable multi gpu" though... )
Thank you so much!
coilbook
can anyone help me too
Do i need single mode? Right now it is chosen as multiple?
Thank you
FooZe
coilbook wrote:can anyone help me too
Thank you
This setting will probably not matter. I would leave it at the default.
coilbook
Thank you
Thank you
FooZe
The setting you need to make sure is off, is this one:
