Problemrendered image viewer C4D .
ploni
Hello,
Why rendering calculated in the viewer C4D is it different from the picture calculated in the Live Viewer?
In both cases, I used the same settings
Thank you for your help
what's the different? I see that only post effect is not same. Have you checked post settings?
ploni
Where I chek the effect in C4D?
plugin can set the post from camera tag or settings->post. Which one is activated?
ploni
First of all thank you for your help and sorry for my English.
I'm not sure I understand the question, but I send you a screenshot for answer.
Hi, you're welcome. Thanks for sshots. Propably, it's a issue on glare which is seen on old versions of Octane. What happens on same render size and same maxsamples? Also you may check it on 2.14
ploni
Again I prefer to respond by screenshots.
ploni
....I take this trade to congratulate you for your work. Octane is a renderer fantastic.
