Newbie with Octane for C4D, directions?
kaoselite
aoktar wrote:demo version is based 2.06. We have recently added support of c4d shaders in background. Anyway you can use a image in background for demo version. Be sure alpha is on. Btw, background mixing is done by plugin and has not any effect on octane reflection/refractions.
Thanks for responding, i tryed everything, the alpha is on in the render options, there' s a way also to hide the HDri octane sky but make it affecting the scene? Thanks :)
check please this scene and let me that helps to you
matte&back.zip
(271.62 KiB) Downloaded 184 times
sirkaoselite
aoktar wrote:check please this scene and let me that helps to you
Thanks! I see that it works, you used C4D R15? because i use C4D R16 and the same procedure doesn' t work but if i open this scen it works in R16
