old school exposure
abstrax
Hi all,
Since some people miss the old school exposure settings for reasons that are totally beyond me, I have whipped up a little Lua node graph that emulates the old exposure settings:
old_school_exposure.orbx
(3.37 KiB) Downloaded 1401 times
Just download the file and import it into your project (via RMB click in the node graph editor -> Import...) and connect it with the exposure pin of the camera imager node like:
Cheers,
Marcus
p3taoctane
THough it may seem like you are creating a bit of code that is old school ... being older than school myself... I love it
Peter
Hi Marcus,
first of all, the lua node is fantastic, thanks for sharing this example ;)
here is my simple version but i don't think is correct in terms of calculation:
EV_exposure.orbx
(2.73 KiB) Downloaded 788 times
could you have a look at it?
ciao beppe
roeland
The exposure on a camera is a logarithmic scale, +1 EV means double the exposure. The formula is exposure * 2 ^ EV.
Check the times you typically find on a shutter speed dial:
  • 1/1000
  • 1/500
  • 1/250
  • 1/125
  • 1/60
  • 1/30
  • 1/15
  • 1/8
  • 1/4
  • 1/2
  • 1
Every stop doubles the exposure.
Roeland
thanks roeland for the info ;)
fortunately for my old brain, Marcus has create a brilliant solution that solves my needs :)
ciao beppe
Phil_RA
The reason it was useful to have the three settings is to match a photo's EXIF data. I'm trying to make sure the scene I'm working on is physically correct, so using the exif data and putting in the same values allows me to make sure that mights are of the correct intensity.
Return to “Lua Scripting”
