Pens
Silverwing
can you tell us more about the ilumination and camera response you used?
Sure,
The scene is lit by a HDRI and one area light.
The HDRI is one of an interior I thought would fit the scene.
I chose to put an extra area light in there to get more color contrast in the scene.
So I made it orange to simulate the color of a tungsten desk lamp.
I moved the HDRI so the main lighting comes from the right then I moved the orange light to the left.
Normally this gives a good looking lighting situation. I normally avoid to have a source of light from the same direction as the camera as it flattenes the image.
Hopefully this gives you a bit of an overview.
EDIT:
I just tweaked everything till it was looking good. I don´t know the intensities by heart ;-)
The HDRI had an gamma of 1 but I would have changed it if it would have benefited the picture.
I also didn´t use a camera curve on the render. It was rendered as linear EXR.
You have to understand that this although its made with a physically based renderer is not painting by numbers but a rather artistic process.
I know the rules (physics) and then I go by them and sometimes break them if it seems legit. What matters in the end is that the picture looks as you want it to look :-)
Cheers,
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
waterthinking
very interesting setup
how much intensity you give to each light? hdri to fill and emitter to light, equal, or viceversa?
also the hdri..you use it with gamma 1.0?
last but not least, what camera response did you use?
thanks in advance!
pxlntwrk
Shaaaarp! :shock:
pxlntwrk.net
bbeepp
Wow! Awesome quality :)
i7 2700k 4.5Ghz - 32GB ram
GTX 780 (3GB)
OS X 10.9.5
vudumotion
One of the most realistic renderings ever. Awesome work Raphael, hammer geil!
Dual Intel Xeon E5-2697 v4, 128gb of ram, 4x 1080Ti Hybrid + TITAN X
http://www.vudumotion.com
Sportler
Good stuff!
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
Matteo3d
really fantastic, impressive!!!
What shader \ material you used for glass \ plastic ?
win 10, 64 gb, 2x 1080ti
Yan
This is insane!! Great Job.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
smicha
How come I've missed your post :shock:
I remember your previous works but this is so real.
pabloportorodrigues
this is really insane, amazing work.
