Hi Paul,
Just wondering if it would be possible to add a surface edge render setting into the octane plugin (possibly in the render window under the normal/clay/clay colored/normal edge/clay edge/clay colored edge??) or elsewhere with the ability to adjust the thickness of the edge?
It's currently possible to get this type off result using the Rhino display modes (see attached) with Display mode>Surface edge settings>Pixel edge thickness. However, it would be great to have this function within the octane plugin and is really nice when doing more illustrative/informative renders.
Not sure if anyone else would like to see this function?
Surface Edge Render Request
This is sort of possible at the moment by post-processing the Beauty and Wireframe render passes (although wireframe is a bit different to edges). In general, an unbiased renderer is aiming to get photo-realism, so features and effects that are not photo-realistic are not the aim of the renderer.
I understand where you're coming from and to be honest it's not something I use all the time. I know I can post process this effect but it is time consuming and for a certain look it would be great to have this built into Octane.
BTW the plugin seems to be really stable now and with network rendering enabled in our studio our render times are really quick. They'll be even quicker when we get our quad titan machine on the network!
Win7 pro 64 / i7 4930 3.4 6core / 2x gtx 680 4gb / 32gb DDR3
Hi Tipperz,
You can achieve the look you are after by doing this. Please see below. I use this frequently to send over concept ideations to clients.
Make a Mix Material.
Put a Dirt Node in the Amount Pin.
Your First material is your main material, in this case, a glossy red.
Your Second material is your outline color, in this case black.
I hope this helps.
I hope this helps.
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Yes, the dirt shader is "by object" - so I don't think it will calculate the dirt effect between objects - so perhaps try merging all the geometry in the scene into a single object. For internal lines you may be able to feed a mix node (with a dirt node and an inverted dirt node) into the material mix Amount pin.This is a good work around although it doesn't seem to like internal corners and only seems to render them when the objects are separate? Weird?
- prehabitat
Great work guys,
I regularly do this kind of output - partly because I don't have time/library to support photorealism for every concept I need to communicate.
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
