Clay noise and specular flicker 2.14
Syd_86
Hello, I have two problems with the beta version 2.14.
1) What has happened to the CLAY rendering mode. Because it generates all this noise?
2) How is it that in the early stages of rendering the specular component creates flicker. For 20 seconds is visible.
Thanks.
info:
OS W8
GPU gtx Titan - Geforce Driver 344.75
abstrax
What is the coherent ratio you are using? The flickering is caused by it and probably the noise artifacts, too.
Syd_86
Coherent ratio is 0.000
if you look at the second picture you can see a lot better.
abstrax
This looks like a hardware problem. This is how it should look like (tested in 2.14):
Syd_86
I do not think it is a hardware problem.
2.06 2.13 2.14
abstrax
Syd_86 wrote:I do not think it is a hardware problem.
2.06 2.13 2.14
Looks you are right. I can reproduce the problem sometimes. Something doesn't seem to be initialized correctly.
Syd_86
This problem is even more pronounced if there is the jump from PMC to Path Tracing to Direct lighting, in start render.
PMC does not create noise, but go crazy after this jump, Direct Lighting and Path Tracing.
abstrax
Syd_86 wrote:This problem is even more pronounced if there is the jump from PMC to Path Tracing to Direct lighting, in start render.
Yes, that's how I reproduced it, too. Should be fixed with the next release.
Syd_86
Thank you! ;)
