Thank you, because of you're suggestion i realized, this is also very usefull when you want to use more than 1 g2f figure in one scene (both with Redspec TGX)..just merge a new scene and add the second shader set to the second figureSimonJM wrote:One small point which may be of use. The documentation pdf says to load Daz Studio by double-clicking the RedSpecSSS-supplied .duf file. Whilst that does, indeed, work it will also have it's effects wiped out my loading a new scene. You can also get the textures at a later stage by merging that .duf file into an existing scene.
