fireflies on desktop AFTER octane crash!
[gk]
Hey.
I got a scene I hope its only that one.
It crashes Octane and then the Specular/glossy fireflies continues to be present, but not inside the render window ( as app crashes and disapears ) but all over my monitors..have to reboot to make em go away.
check them here, its mild screenshot but i can make 1000 apear with moving windows around :o
Amiga 1000 with 2mb memory card
enricocerica
Yep I got the same thing much more than once, I had to reboot each time to remove them. I didn't worry about that, it's not the first time a graphic card has strange behavior once it is stressed ;)
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
Sam
That's both funny and scary at the same time :lol:
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
radiance
Could you zip up something (OBJ+MTL) and get it to me ?
I think i've seen this before, would be cool if i can figure out why this happens.
Have you checked if your units are too large ?
eg, if you import the scene and change in the File -> OBJ import preferences, the meters to say centimeters,
then see if it still happens ?
Radiance
[gk]
I cant send the specific scene unless you sign a NDA.
Ill try check the scale works.
radiance
ok, check that, if it resolves the issue,
i already got a scene to replicate it :)
Radiance
