OctaneRender® for Maya® 2.11.1 - 5.6 Win [OBSOLETE]
Moderator: JimStar
JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® License" priced at 199€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
CHANGES AND FIXES SINCE LAST RELEASE:
  • Switched to Maya 2015 ext1 sp5 for Linux.
  • Few minor fixes.
DOWNLOAD
OctaneRender for Maya 2.11 - 5.6 (31.8MB autoinstaller file)
OctaneRender for Maya 2.11 - 5.6 Demo (30.0MB autoinstaller file)
Yours,
The OctaneRender™ Team.
RickToxik
Hi Jimstar, it seems that the refraction of some objects will render differentlty depending on their position in world space.
I ended up figuring it out in this thread. Thanks!
http://render.otoy.com/forum/viewtopic. ... 84#p210784
Jolbertoquini
Thanks Jim! :D
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
p3taoctane
I am still getting a freeze when I try and create a environment sun/sky node
Anyone else?
Peter
abstractmedia
p3taoctane wrote:I am still getting a freeze when I try and create a environment sun/sky node
Anyone else?
Peter
I am getting the same thing. Maya locks up until I force quit. It even happens if I import an old sun/sky from another file. Or happens immediately when I click the 'Create Octane sun/sky environment node' from the OctaneRender shelf.
p3taoctane
Glad it is not just me.
Jimstar... any idea when you might get around to fixing this one?
solomon
hmmm, mine is not freezing, what Maya version are you using?
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.solomonjagwe.com | http://www.nkozaandnankya.com
p3taoctane
Win 7 64 bit Pro
Maya 2015 SP4
solomon
p3taoctane wrote:Win 7 64 bit Pro
Maya 2015 SP4
ah, I am using Maya 2014 on Win 7, so it must be a 2015 problem
Solomon W. Jagwe
abstractmedia
Must be. I am using Maya 2015 SP5
Return to “Autodesk Maya”
