OctaneRender™ for Blender 2.06 - 6.5 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed coordinate space bug in Projection nodes (reported by aLeXXtoR).
  • Fixed modified geometry bug (reported by RajivMudgal).
  • Improved license activation proccess. Now you have the separate "Octane server" rollout.
  • Linux libs are now included into Linux installer package.
  • Minor fixes...
Blender Octane Edition - 6.5 (2.72) (57.3MB autoinstaller file)
Octane Server - 2.06 - 6.5 (8.9MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.06 - 6.5 (8.0MB autoinstaller file)
aLeXXtoR
Thanks, JimStar!
There is one another issue that I forgot to report and it occured again this night: if I render my scene with Sampled Motion Blur and if all objects (and camera) in the scene have no motion in the given frame, Octane correctly renders only the 1st pass and skips all other (at least it looks this way) — in result I get a very grainy frame.
P.S.: not a bug, just a notice (for animation artists first of all): Sampled Motion Blur is pretty slow — I had to set amount of samples from 15 to 20 to get smooth results, but because of server-client exchanges render time increased by about 30-35% per frame. Does anybody tested render speed difference w and w/o native MBlur in the Standalone?
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Elonius
Hey Jimstar I think I've found a bug. There seems to be artifacts inside the mesh using the specular shader. Do you know what is wrong here?
Test 1.blend
(2.48 MiB) Downloaded 272 times
FooZe
This is caused by the bottom of the pyramid and the plane occupying the same 3ds space.
Either move the plane down a fraction, or the pyramid up, or remove the base plane of the pyramid.
(this problem is not limited to octane alone - see the attached screenshot of blender doing something similar in the 3d viewport when viewing the underside of the plane where the pyramid base is as well).
Garquitectos
Many thanks for the new version! Every version, the plugin is more solid and workable
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
JimStar
aLeXXtoR wrote:There is one another issue that I forgot to report and it occured again this night: if I render my scene with Sampled Motion Blur and if all objects (and camera) in the scene have no motion in the given frame, Octane correctly renders only the 1st pass and skips all other (at least it looks this way) — in result I get a very grainy frame.
I can't reproduce it on my scenes... Could you perhaps give me the scene where it is reproduceable for you?..
aLeXXtoR
JimStar, sent you via PM.
WebSite
Showreel
ROUBAL
Hi Jimstar,
I have been away from Blender and Octane for a while due to health troubles, and I just discover the 2.x Plugin. Thanks a lot for the great work. :)
Just in case you wouldn't know : I have had to copy/paste the MSVCR120.dll and VCOMP120.dll files from the official Blender release into the BlenderOctane folder, as they were missing in the release. Not a big deal though !
Well, first trials with the 2.06 - 6.5 Win : When looking in the preferences, no GPUs are found in Cuda field. Even if I select Cycles render. Precision-X Gpu monitor shows that GPUs are working for Octane, but it is annoying because I will have to switch between the official Blender and Blender for Octane in my workflow, instead of just switching the Render engine within Blender when needed...
JimStar
Next version HERE.
Return to “Blender”
