This is a test render I used Pathtrace kernel for that the render took 3 minutes a frame using Path Tracing kernel with 8000 samples at resolution 720p for the image I have post here is a HD format with 16000 samples took 8 minutes a frame.
Also the setup for light was quite easy, I shoot a HDRI at my daughter bedroom and that's it.
Is animation I have problems to render a batch render at Maya because I use Alembic at maya no problems for renderview but batch render to have my animation doesn't work sad days for me!
Hope you like it.
