Hi Huv,
do you mean this settings window?
Version 2.12.2 - final (updated on 18.11.14)
- a1.jpg (34.07 KiB) Viewed 4877 times
Ho aoktar,
this window.
I define my settings to render an image, jump to perspective view, come back to this render setting window, and all my settings are set to the default values...
Of course, after installing 2.12.1, i've deleted, and created totally new octane startup layout.
this window.
A bad behaviour occured after my efforts to allow the gpus to enter sleep mode. Settings window doesn't takes scene settings if you save it to layout. When you call open command from menu or icons it shows values. I think this is similar behaviour.Huv wrote:Ho aoktar,
this window.
can you try to re-set values after jumping back to default? Let's see is it being again.
Sorry, my english is maybe not very good...
I don't mean to save these settings that they can appears again when i create a new document...
I just mean that when i'm working on a scene, i set my octane settings (low settings) to test materials or light...
Finally i go to the perspective view to change the position of the camera (or something else), and jump back to the octane render settings to adjust the samples to get a better quality, and at this moment, all the settings entered few minutes ago, just desapeared, all of them seems to be reseted, and get back to their default values...
Huv,
sorry still i cannot figure it. Is it possible to do a short video capture to show me?
Ok, so :
I'm working on my scene, going to octane render settings and set up what i need (you can see here, how i'v made my layout) : I finally need to change the camera position, so going to my perpective view : Than, i want to go back to my octane render settings, and... reset to their default values :
Understand this. But i have no idea why occurs. is it doing one time or repeately after changing again? Is this occuring on a spesific scene or any scene? This does not occurs on my trys
Well, not really able to say why neither... Just installed the 2.12.1, so can not tell if same problem on other scene...
I have to try... and let you know
Good Day. My Analysis of what I have found
Looks like with 2GPUs Rendering is right on the small top left BLOCK
- issue_2-twoGpu_gpu.mp4
- my video analysis
- (33.03 MiB) Downloaded 4022 times
- issue.zip
- c4d project file for test2
- (387.08 KiB) Downloaded 256 times
Hi valters,
what's your gpus, nvidia driver/plugin/c4d and os versions?
