OcDS 2.1 PRE RELEASE
Moderator: BK
Laticis
This is a Sphere :) - Displacement ROCKS
Edit to add second image.
jimgale
doesn't work... dragging from the LiveDB adds only to the Unused - doesn't link to the sphere (even tho I dragged it there, and to the name).
cyprine
licence sorted out with support.
bugs found so far:
+ v1.x MyPreset didnt convert, causing daz to crash
+ v2.x MyPreset if applied to multiple areas cause daz to crash
+ RGBcolor node doesnt update, at all, remains default grey
+ Reload geometry didnt put the hair back on my figure head.
hope this helps the track & squash of bugs.
Laticis
One more displacement test....
t_3
@everybody posting his/her findings - thanks! most of it is already fixed, whereas most of the things resulted from a few very basic methods i had messed up while 2.12 api integration (like copying nodes around which happens all the time when i.e. downloading live db materials, or loading saved content).
apart from that one observation i made when testing the tonysculptor live db mats: the orginal macros (now called "node graphs") are set up very decent, with descriptive naming for the different nodes and inputs, but unfortunately the plugin api provides only a single collapsed material node out of all that...
means you may still use my "smart unfold" feature to recreate the node graph in a way that provides single endpoint nodes to control color, bump, specular and so on, but there is no way to restore the node names, since they are just not there when the plugin retrieves the live db material from octane...
AlfaseeD
t_3 wrote:@everybody posting his/her findings - thanks! most of it is already fixed, whereas most of the things resulted from a few very basic methods i had messed up while 2.12 api integration (like copying nodes around which happens all the time when i.e. downloading live db materials, or loading saved content).
Thanks for the update!
Can't wait to work with this new version :)
Laticis
Thank you very much :)
TRRazor
Appreciate the input and feedback, t_3.
Any estimate on when we will be able to download again?
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
t_3
TRRazor wrote:Appreciate the input and feedback, t_3.
depending on your time zone during the day (us) or overnight (eu)... apologies for any not mentioned regions...
orion_uk
...or Dimentions in time & space :P
This Tardis of mine is temprimental enough as it is! :lol:
:roll:
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
Return to “DAZ Studio”
