OcDS 2.1 PRE RELEASE
Moderator: BK
larsmidnatt
thanks for the update, sadly octane is having license issues at the moment...so i can't authenticate. Not plugin related issue but *sigh*
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
Laticis
Me too...
larsmidnatt
Ignore all this it is working now, but this is what was happening. I can log into the 2.1 plugin now.
seems like my licenses are back up in my account so im going to try again.\
I can connect with 1.1 plugin, but not the 2.1 R2.06 Oct 2 plugin. When I use the 2.1 plugin it won't connect/authenticate. If i use the activation manager it deactivates my account. It states there is a connection error or no internet.
Then when I try to use 1.1 it wont work either. So i guess the license issue is plugin related. I did not have this problem with the earlier preview.
Also, it wipes out my Octane live account page on the website. Error getting license list But after a few mins of waiting that resolves itself and my licenses show up again. then I can go back to using 1.1. If I try to run 2.1 the cycle restarts.
Win10 x64
i9 10900k 64GB
2080S 8GB
Laticis
Confirming same here.
Just can't connect to Octane Server, even via Stand Alone.
larsmidnatt
t_3 do you still plan to support the 1.1 materials like you said a few months ago? I noticed 1.2 was mentioned specifically in the notes with not mention of 1.1.
@Laticis, yeah I kept getting knocked out too. Strange cause the offline data isn't working either.
Win10 x64
i9 10900k 64GB
2080S 8GB
Laticis
Still no luck from my end :(
t_3
Laticis wrote:Confirming same here.
maybe a octane server issue?
i just checked with 2.1 (from the updater) which worked, then 1.5 told me "not activated", and the other moment it also worked.
pls keep me posted if these issues persist - since the activation mechanism is a bit different in 1.5 and 2.1 it might be still something i need to resolve on my side...
„The obvious is that which is never seen until someone expresses it simply ‟
t_3
larsmidnatt wrote:t_3 do you still plan to support the 1.1 materials like you said a few months ago? I noticed 1.2 was mentioned specifically in the notes with not mention of 1.1.
http://render.otoy.com/forum/viewtopic. ... 86#p209586 ;)
i'll probably need you as tester for it anyway...
larsmidnatt
thank goodness! I hate to be all stubborn about it but I literally have over a year of work in 1.1 so its really relieving to hear that. I totally missed that post, thanks for pointing it out.
Win10 x64
i9 10900k 64GB
2080S 8GB
Laticis
Everything things seems to be activated now and licenses are up and running but DS is not seeing the plugin at the moment.
Return to “DAZ Studio”
