OctaneRender 2 for Inventor [OBSOLETE]
Autodesk Inventor (Integrated Plugin developed by Paul Kinnane)
I have refreshed the installer at the top of this thread with:
2.12.1.3
- Compiled with Octane 2.12.1
- Resolved issue where Weld elements were stopping the Viewport from opening
Profius
Can you pls send me one of the big assemblies causing this error and I will take a closer look.
Cause it is hard to send thousand of files, I tried to delete unnecessary parts, until error is stay. And I find out that the quantty is not the main problem. Please, try to render files in attachment.
You will need to rotate your part if you do this.
It is possible only in assemblies.
Alternatively, place an Inventor plane to use as the ground plane.
Does standart Inventor plane renders in Octane?
You would get a Cuda error similar to "Can't connect node '?????'
I received similar error once. If it will apear again, I will let you know.
Viacheslav
TEST.rar
Error 702
(1.12 MiB) Downloaded 1205 times
Win 8.1 64bit, GTX780 Ti, i7-3660x, 32Gig RAM, 344.75, Inventor 2015, plugin v.2.16
Hi Viacheslav
I downloaded and rendered the files in the attachment and got no error - sorry.
I may have used very thin box rather than a plane. Any flat 3d surface can be used as the ground plane.
Profius
This is definitely materials problem. Part materials was reassigned to green in test assembly. When I have changed it to original part colour, problem is disappeared.
Maybe localisation is a problem, like in node error?
And it is possible to add function that change default Octane axis? :)
If you can give me some more info on the issue, or a sample file showing the problem, I can look into it in more detail. If you have a material "Steel" in assembly A which is blue, and a material "Steel" in assembly B which is green - the plugin can only handle one Steel material, so it will use the first one encountered. So if you have duplicated material names in parts, they should be the same Octane material - or rename them so they are unique. I hope that helps a little....
Octane assumed Y is UP. Whilst I can trick the plugin into using as up, things like Perspective Correction and Daylight then do not work correctly. So the best setting for Inventor is Y = UP.
Profius
Maybe this will help. File of assembly is the same - "test".
Hi Viacheslav - I don't get that Cuda error when I render that scene. Could you pls post a screenshot of the plugin Settings/Configuration dialog pls?
Thank
Profius
Hi Paul,
All settings is standard.
There is more issues:
- welding is visible always in render, even if it hidden.
- its impossible to attach materials to some parts in assemblies. They rendering as white and don't response when I click on them in Octane viewport. This is floating problem. Each time the problem parts are different.
Viacheslav
Can you post a screenshot of the Setting dialog pls?
There is no Visibility option for a weld. How are you hiding it pls?
Can provide an scene which demonstrates this problem pls?
2.16.0.5
- Compiled with Octane 2.16.
- IMPORTANT: Requires Cuda driver 344.x or later
- Various additions/enhancements to emitters, including addition of "Surface Brightness" and "Cast Illumination" pin. See Octane 2.15 Standalone release notes for details.
- Removed ISO and FStop Imager pins. See Octane 2.15 Standalone release notes for details. Scenes saved with plugin versions prior to 2.16.0.5 will have the exposure converted to the new scale, however your default rendertarget "exposure" will not be converted - so you may need to adjust the default exposure and then "Save a Default"
- Daylight illumination power has been re-calibrated (pls see Octane Standalone 2.16 release notes for details). You may need to tweak the Daylight power of some pre-2.16 scenes to compensate.
- If the configuration file becomes corrupt, the plugin gives an option to the user to return it to default settings
- The plugin is now out of the Open Beta stage
Return to “Autodesk Inventor”
