1st render. Gamer tag / grenade
Cronicash
My first go with a model I was using back in thea and kerkythea...
"BFG" = bay fraternity of gamers...
Modelled in sketchup. "cant wait for the plugin/ exporter to arrive"
EVGA sr2 2x x5650 12c/24t| 64Gbddr3 1600mhz | 4x gtx580 3gb on h20|4x 128x corsair ssd | 2x Strider 1500watt + 500watt |swiftech Blocks ,3x quad rads + dual rad (two loops)||8Tb|Laptop:Dell XPS 1730| 4Gb| 2x 9800GTX sli
Portfolio/blog
radiance
nice start ;)
the 2nd one is a bit noisy though...
Radiance
Cronicash
An older design i done a while ago, a little more refined...
Gave it some zing...
Mosfet H20 block. Translucents still doing funny things with sketchup .obj export when i tried..
Diaphragm pump
Was trying to get the same type of semi opacity like i got in thea, but was unable to get a similar result. Was trying to make a non glossy specular with a high diffused colour threshold but wasn't able to.... Going the other way around making "glossy" with opacity wasn't achievable either so far. As opacity seems to have more of an overall fadeout effect, not real translucent allowing light through... Any suggestions would benefit allot thanks.
Portfolio/blog
radiance
you can make a diffuse material and connect a colour to the transmission component,
then it turns into a diffuse transmitter.
we don't have glossy glass yet. that's coming soon.
Radiance
Cronicash
radiance wrote:you can make a diffuse material and connect a colour to the transmission component,
Radiance
Thanks.
Will all materials have an emitter option when its available?
Portfolio/blog
radiance
Radiance
Thanks.
yes ;)
Radiance
Cronicash
Could have done way more passes. Can't wait for emitters... Will we also be able to use IES lights? Just as with models its not always easy to get the desired lighting effect imo...
Portfolio/blog
Cronicash
I let this one run for an hour....
Portfolio/blog
tedhaoyang
l like 1,3,4. nice work.
Nichod
IES lights are suppose to be coming at some point. Nice renders.
Windows 7 64bit | AMD Phenom 9550 | 6 gigs ram | Blender, Silo, messiah 4.5 |
