i have imported the sequence file_0001.jpg (infact read it like sequence)
but in render dont work
32 bit plugin ...
image sequence as environment dont work
- Andygraph3D
not sure this was ever fixed? or i am mistaken?
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
You may be right - the Animation process only loads animated images each frame for Octane "Materials", not for the Octane "Environment", so this is a shortcoming. I would have thought animating the Environment HDR map would give very poor results - and I cannot think of why this would be needed. Are you able to give some more information on why you need this pls?
- UnCommonGrafx
To have your lighting environment change;
In order to achieve some extremely difficult lighting, as in underwater faked caustics;
Because all parameters are said to be animatable.
I'm not that guy, nor do I use poser, so pardon the intrusion. However, I can see the posters desire to have such a thing and thought to chime in.
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
This is not the case with the Poser plugin - only a very small number of Octane settings can be animated.Because all parameters are said to be animatable.
- Andygraph3D
This a sad answer paul ..
i think about a object move inside a forest background real footage with a hdr move about the same real forest so all light and shadow follow it on object in move ...
Paul i talk about VFX .. cgi and footage
this feature IS VERY IMPORTANT!
Where are you getting the HDR image sequence moving through the forest from?i think about a object move inside a forest background real footage with a hdr move about the same real forest so all light and shadow follow it on object in move ...
- Andygraph3D
A forest hdr probe animation ? Is not complicate make it.
Anyway the forest was a example ..
I dont understand if the problem is octane standalone software or the plugin ?
- Andygraph3D
this is a example how is important hdr sequence in a compositing cgi and real footage:
capture hdr probe footage
http://www.youtube.com/watch?v=pnXrLRK6Eh4
use it on 3d object on footage source
http://www.youtube.com/watch?v=I12tZ1TnCrE
Thanks for supplying the addition info. At this stage the Poser plugin does not support image sequences for the Environment map. It could potentially be added in the future, however it would be a complex change and need a lot of effort testing, so would not be a quick change.
