IES light orientation not working on light planes
Moderator: JimStar
ciboulot
Is it normal that the Ies files orientation doesn't work with the light planes? It is impossible to make them face the right direction, like the direction in which the light is aiming.
Is there a solution?
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
RickToxik
I had this problem too, but I was not sure if I was using the IES correctly.
ciboulot
Hi Richtoxic,
thanks for your answer. I did some tests with a huge library of IES. None of them work. I found out that it works with the spherical lights.
BUT, it was working before with the planes, so I don't understand why this doesn't work anymore. wIth so many other things, like the orientation of the HDR with the sun and sky node. (who would think of entering a value in the translate Z before the orient Y accepts to work in the transform 3D node?)
Return to “Autodesk Maya”
