OCTANE BENCHMARK: Submit performance scores for your rig!
grimm
Another test with 2.12, looks like the renders are getting just a little bit faster for the 980.
DL - 15.06 Ms/sec
PT - 4.86 Ms/sec
PMC - 3.59 Ms/sec
Coherent mode:
PT - 5.22 Ms/sec
DL - 18.86 Ms/sec
Godstrike
Single GTX 590 running Octane 2.12
PT - 8.17
PMC - 5.17
DL - 24.65
Coherent mode
PT - 8.55
DL - 31.09
2 x GTX 590 running Octane 2.12
PT - 16.25
PMC - 10.34
DL - 49.23
Coherent mode
PT - 17.18
DL - 62.4
* Alpha shadows turned off.
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
smicha
Overclocked watercooled TITAN + 3x780 - see the footer for details
2.12
DL 171.45 ms/s
DL 190.91 ms/s (coherent mode)
PT 32.28 ms/s (path term power 0.3)
PT 34.78 ms/s (path term power 0.3, coherent mode)
PT 60.27 ms/s (path term power 1, coherent mode)
PMC 24.48 ms/s
PMC 21.45 ms/s (alpha shadows on)
PolderAnimation
5 x 780 ti overclocked (@1150mhz, aircooled) - Octane 2.12
DL 225.73 ms/s
DL 249.17 ms/s (coherent mode)
PT 42.56 ms/s (path term power 0.3)
PT 46.32 ms/s (path term power 0.3, coherent mode)
PT 79.89 ms/s (path term power 1, coherent mode)
PMC 32.28 ms/s
PMC 28.23 ms/s (alpha shadows on)
@smicha I used your lay-out hope you don't mind =D
Damn you are pushing your 780 very hard, how many mhz are they running? They are almost preforming as good as my overlocked 780 TI's. Which is very nice.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
smicha
Great scores!
BTW 5x780ti are 14400 cuda cores vs mine rig has 9600 cuda cores (you have exactly 50% more of cuda cores) and performance is 31% faster. Potential room for overclocking :)
Do you use raisers? Or it is via network?
These scores are at 1228mhz on core and 7006 mhz on mem (and 40C temps.). But they go even up to 1300 mhz on core on stock volts.
glimpse
Guys (Smicha, PolderAnimation) Your rigs are crazy! =) what a performance!!!
Think, I've seen P's rig: ribbon cables & modified case - really nice solution! =)
smicha
Glimpse,
Since yesterday you've made me thinking about getting a STH10/SMH10 additional pedestal, put additional 2x560 rad there and go with 4x water-cooled Titans Z :) I have just enough room for a second 1500 W PSU. So pity there is no budget for it now. But next year ... :)
PolderAnimation
Its one computer with risers, I posted it a couple of month's ago (http://render.otoy.com/forum/viewtopic. ... &start=390).
I never tried to go past 1160mhz core and 7000 mhz for the memory.
Specially in the summer they can get around 65 degrees, at the moment they will hit 48 degrees at the max (its autumn here).
can you run a bench on one 780 watercooled? to compare against one 780 Ti aircooled?
780 ti aircooled at 1150mhz DL (no alpha shadows) 45.23 Ms/sec
smicha
34.04 ms/s boost stock: 980mhz core, 6010 mem. 36C
42.15 ms/s oc: 1228mhz core, 7012 mem. 38C
44.12 ms/s oc: 1306mhz core, 7012 mem. 39C
49.12 ms/s oc: 1306mhz core, 7012 mem. + coherent mode, 39C
noctua 1500rpm fan speed set to 25% - silence
PolderAnimation
nice thnx!
Edit: does memory speed effect the performance?
