OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
samhal
RGUS wrote:The viewport no longer dynamically updates with new light position when using HDR Light Studio, a refresh of the viewport is required with every light position change.
Was this expected?
It seems to work for me Deane. Hmmmm.
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
Was this expected?
I cannot reproduce this issue. Have you tried the usual reboot, reinstall, retest?
RGUS
Was this expected?
Yup... had to do that to upgrade to this version of the plug-in... however... after another reboot etc...as you have asked here... things seem to back to normal. Whew!
Thanks Paul
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
I think what happens is something HDR Light Studio stays in memory after you close Poser, then when you rerun Poser, the direct link does not work correctly - so rebooting fixes it. You can also open the Task Manager and close HDR Light Studio (when Poser is shut down) to achieve the same thing.
Masterstroke
It has nothing to do with HDR Light Studio. I don't have that, but after changing my environment map HDRI the scene is black.
wimvdb
Masterstroke wrote:It has nothing to do with HDR Light Studio. I don't have that, but after changing my environment map HDRI the scene is black.
Are you sure nothing is blocking the HDRI? Like a skydome?
If there is a skydome, uncheck the Shadow Visibility in the skydome mesh
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Masterstroke
No skydome. My setting is to daylight, wich works fine first. After changing to textured envirinment and loading a HDRI map the Environment is allmost black.
Masterstroke
don't understand anything at all anymore. Not black this time, it just doesn't change the HDRImage. It stays the same. Here is a phyton error message, that I don't know, what it is about:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1639, in <lambda>
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2676, in EventNodeChanged
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 3006, in LoadImageFileWithDialog
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 854, in SetOctaneApiNodeValue
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3034, in displayError
ValueError: Error in SetOctaneApiNodeValue - null Octane node for node texture, node type = image
Masterstroke
Could it be again, that my Poser and Octane plugin is not on C-drive?
RGUS
No they're not... (back to normal)...
So here's the sequence....
- Load a scene (anything)
- Render with default texture environment- Change Environment to daylight
- Right click for HDR Light Studio
- Add a light
- Move that light
- No change in the Octane Render viewport.
- Exist Poser
- Exit all other applications
- Restart Windows
- Load Poser
- Render with Firefly.
RAM: 64GB
Return to “Poser”
