OctaneRender® for 3ds max® v2.11.1a
Karba
Main changes since version 2.11.1
  • Added static noise parameter for Direct Lighting and Path Tracing kernels.
  • Fixed render element clamp.
Main changes since version 2.10
  • Render passes/elements.
  • Region render for production render.
  • Added highlight compression option to camera imager node. Using this option, you can reduce burned out highlights by compressing them (which decreases their contrast). This works similar to the Reinhard tone mapping.
  • Added pins "hue", "saturation" and "contrast" to the color correction node to control hue, saturation and contrast of the input texture. Since Octane textures are sampled spectrally, hue and saturation don't work perfectly, but as long as you use them not too aggressively they should do the trick. We might have an idea how to improve that, but that will require some more work.
  • We had to remove the pins "brightness scale" and "black level" since we ran out of fields in our color correction shader node.
  • Added new noise texture node which currently has 4 noise types: "Perlin", "Turbulence", "Circular" and "Chips". "Perlin" is like the turbulence node with "use turbulence" disabled. "Turbulence" is like the turbulence node with "use turbulence" enabled. "Circular" is a Worley noise and "Chips" is a Voronoi noise.
  • Fixed hanging render kernels for some displacement cases (causing some of the dreaded CUDA errors).
  • Fixed hair normals.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... _11_1a.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=33&t=42854
Yours,
The OctaneRender® Team.
mykola1985
Outstanding stuff!!! downloading... thank you Karba!
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
gabrielefx
thank you!
MistAjuliax
Hi Karba,
thanks for new release :). I have a question about motion blur and pflow source. When i set my particle to movable proxy, i can see in real time the moving of my particles but motion blur doesn't work as i expected. Oject motion blur is very buggy and block to 1samp/pix and constantly refresh ... I have to set to vertex motion blur to see the effect, and it's only visible from the frame emit stops. I'd like to know if it is a bug or a limitation and if a pflow full support is planed ?
Thanks, regards.
no motion blur
no motion blur
motion blur
motion blur
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
Karba
MistAjuliax wrote:Hi Karba,
thanks for new release :). I have a question about motion blur and pflow source. When i set my particle to movable proxy, i can see in real time the moving of my particles but motion blur doesn't work as i expected. Oject motion blur is very bugguy and refresh constantly to 1samp/pix ... I have to set to vertex motion blur to see the effect, and it's only visible from the frame emit stops. I'd like to know if it is a bug or a limitation and if a pflow full support is planed ?
Thanks, regards.
Could you give me the scene?
[email protected]
MistAjuliax
Thanks, regards.
[email protected]
I send you the scene by pm. it's 3ds max 2015 scene, do you need a previous 3ds max version ?
Karba
Thanks, regards.
[email protected]
2015 is fine
Thank you
Karba
got it, thank you
I will investigate the issue.
MistAjuliax
Karba wrote:got it, thank you
OK, thanks.
I'll check your response later, time to sleep for me in france.
Have a good day.
coilbook
For some reason object motion blur is disabled by default now in octane prop Thanks
Return to “Releases”
