strange light distribution
gueoct
i am simulating a light tube parallel to a wall.
The light tube has a black body emission in the emission slot.
for some reason the emission is hundreds of times stronger at the ends of the tube.
Does any one know why?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
glimpse
it has something to do with polygon sizes..-I don't use mesh emitters so often (just on single poly planes, to mimic softboxes),
but I've noticed that if I scale them or tweak their size I have to tweak values too =)
Goldisart
gueoct
glimpse wrote:it has something to do with polygon sizes..-I don't use mesh emitters so often (just on single poly planes, to mimic softboxes),
i increased the number of height segments on that cylinder to have equal polygon size - without luck...
Karba
Set the same material id to every cylinder part.
gueoct
Karba wrote:Set the same material id to every cylinder part.
Thanks! it works.
BUT: What does it mean?
i did a few tests:
Return to “Autodesk 3Ds Max”
