OctaneRender™ Standalone 2.11.1
abstrax
funk wrote:
abstrax wrote:
EDIT: The problem is that all HDR viewers assume that EXR images are linear and apply a tonemapping to sRGB
Thats correct. Every application I have tried assumes the EXR is linear. Photoshop, After effects, djv view, xnview
EDIT: I also just tested NUKE (personal learning edition) and got the same results.
So, in conclusion if the major compositors (AE and NUKE) assume linear EXRs, I think this should be fixed in Octane (only tonemapped EXRs need to be fixed).
Nope, if you want a linear result you have to save them untonemapped which means linear.
funk
abstrax wrote: Nope, if you want a linear result you have to save them untonemapped which means linear.
Untonemapped EXR will save without a camera response. If I like the look of what I see in octane, but want to save in EXR format, then I'm forced to save as tonemapped EXR and re-correct the gamma in my compositor. The other option is to simply save as 16bit PNG.
So if the tonemapped EXR doesnt appear correctly in any application, then what is the point of having it?
I would need to adjust the gamma of all my HDR viewers each time I want to view them, then change my settings back to view all my other EXRs. Don't you guys think this is a problem?
LATER EDIT: I seem to remember reading that EXRs should always be saved without gamma correction but I can't find the page. There is a mention of this on the OpenEXR web site:
http://www.openexr.com/photoshop_plugin.html
OpenEXR images are stored with no gamma correction. By default, the EXRFormat plug-in applies a gamma correction of 2.2 to the image as it is read into Photoshop, so that it will match the color space of other images, and display correctly on a computer monitor.
stratified
There's no point in having tonemapped EXR but that's another discussion and maybe we should pull it from Octane. It's the source of all this confusion. If you still want to do tonemapped EXRs then you need to configure your viewer to hold off on tonemapping (e.g. in djv_view you would tick off image -> color profile).
cheers,
Thomas
funk
stratified wrote:There's no point in having tonemapped EXR but that's another discussion and maybe we should pull it from Octane. It's the source of all this confusion.
That may be true, but it doesnt hurt having an additional format. Especially now that we have passes and can save them all in a single EXR. The advantage is you could save tonemapped passes into 1 file (although I havent really tested this to see how well it works)
stratified wrote:If you still want to do tonemapped EXRs then you need to configure your viewer to hold off on tonemapping
I actually mentioned this in the reply you quoted. Maybe you missed it?
stratified
Yep, missed that part about the viewers.
We can add a correction for this behaviour by applying a reverse gamma correction and then when the viewer applies his gamma it would look good again. Regarding the render passes, if you composite tonemapped images together, they won't add up to the beauty pass any more.
cheers,
Thomas
funk
stratified wrote:We can add a correction for this behaviour by applying a reverse gamma correction and then when the viewer applies his gamma it would look good again.
Yes, you could even make it a preference if you want to keep the current behavior.
stratified wrote:Regarding the render passes, if you composite tonemapped images together, they won't add up to the beauty pass any more.
As I said I havent had time to test. I noticed the render pass saver has a "Tonemap beauty passes" option and I assumed all the passes (except info) would get tonemapped. Maybe they do?
geo_n
I vote for removing the option to have tonemapped exr.
This is a potential source for a lot of problems for users that don't use exr frequently.
Faustik
Hi guys, I don't why but both latest versions 2.11 and 2.11.1 get totally freezed after exporting from C4D r15.037. On the other hand, when I open Octane Stand. and load these previously exported scenes everything works fine.
Faust
Win7 64bit SP1 / i5 2500k 3,3GHz / RAM 8Gb / MB Gigabyte Z68X-UD3H -graphic integrated for display / 2x NVidia GeForce GTX 570 1280MB / HD 1TB
Archicad 17 >> Cinema4D R15.037 >> Octane Standalone 3.00 + Octane C4D plugin 3.00
Rickky
mat id pass is very noisy. is there a trick to make a good one ?
Elvissuperstar007
bug obj export
2.11.1
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
