Use the multilayer EXR files is really easy, you only need to link the render passes node in the render target node editor, set a file name, and select the layers that do you want to be included in the EXR file. You are going to get an .exr file for each frame.thinkman wrote:This is great, Juanjo! Thank you!
Do you have documentation on how to use the multi-layered EXR output? I'm not figuring it out yet.
Billy
This file can be loaded in a post-production software to tweak your rendering with all the information in the layers. For example I am using Fusion here to test the plugin, and all works fine with it.
