2.1 stops rendering in OCtane Preview
C. RAM Capacity (i.e. 6 GB)
thanks Karba I thought this one something elseKarba wrote:You have to solve your hardware issue.coilbook wrote:I noticed sometimes in Octane Preview samples just stop and rendering stops sometimes it stops at 8/1500 sometimes 1024/1500 Render itself works fine
Hi Karba I removed my faulty card but Octane Viewport still freezes. It happens if I open octane viewport, select focus picker, click somewhere on the screen; after that If I enable coherent check box then click on the octane viewport again with the focus picker samples per second just freeze but all video cards keep working at full speed like they are still rendering. Please see short video I attached. I never had this problem until 2.1Karba wrote:You have to solve your hardware issue.coilbook wrote:I noticed sometimes in Octane Preview samples just stop and rendering stops sometimes it stops at 8/1500 sometimes 1024/1500 Render itself works fine
Maybe it is still fresh release
- freezing viewport.MOV
- (1.94 MiB) Downloaded 4481 times
I did as you said, can't reproduce it unfortunately.coilbook wrote:Hi Karba I removed my faulty card but Octane Viewport still freezes. It happens if I open octane viewport, select focus picker, click somewhere on the screen; after that If I enable coherent check box then click on the octane viewport again with the focus picker samples per second just freeze but all video cards keep working at full speed like they are still rendering. Please see short video I attached. I never had this problem until 2.1Karba wrote:You have to solve your hardware issue.coilbook wrote:I noticed sometimes in Octane Preview samples just stop and rendering stops sometimes it stops at 8/1500 sometimes 1024/1500 Render itself works fine
Does error log say anything?
Does error log say anything?[/quote]
lol now it works. sometimes it does sometimes it does not. I attached a log file
- octane 2.10 141002 183701.log
- (32.51 KiB) Downloaded 295 times
Looks like it is an octane bug. We are investigating the problem.coilbook wrote:yes. I even use all GPUs for octane preview. maybe i should disable network for octane previewKarba wrote:do you use octane network render?coilbook wrote: lol now it works. sometimes it does sometimes it does not. I attached a log file
do you use octane network render?[/quote]
yes. I even use all GPUs for octane preview. maybe i should disable network for octane preview[/quote]
Looks like it is an octane bug. We are investigating the problem.[/quote]
thanks ! Also I still have noise where direct light hits objects I posted in the other topic and it still moves chaotically. I guess that's the only way for GPU rendering and you cannot stop light from moving chaotically.
Thank you
Thank you
- nosie.mp4
- (2.44 MiB) Downloaded 4462 times
