Rendering with 2 cards / stranges settings
toketronic
look now my titan is swicht of but down you can se that is the gpu running or mabey i jsut don't understand those settings ?
this is a bug on plugin. But cannot fix it. It show swapped the usages of cards. But not on every system. I'm using a external api to read temps and usage. It gives uncompatible order of gpus against to Octane sdk. If you select any gpu, this means that's active
toketronic
hmm sounds bad so how do i optimizes my computer best now ? when i run only one card it has now gone past the point where it was chrashing but what i really do not understand it that my rendering time is more then 2x as slow as when i was using both cards ?
toketronic
shiiit it chrasht again, only using the titan set as the 480, okay mabey i should send you that scene, i don't what going on but ever since i updated my sytem has been super unstabel, so where so should i send the scene file to and should i try re installing octane ?
Selection is working well. Problem is out of my control. Depends to nvidia api. You can use "msi afterburner" to be sure which is running.
Can you write more clear? I couldn't understand last status of yours.
toketronic wrote:shiiit it chrasht again, only using the titan set as the 480, okay mabey i should send you that scene, i don't what going on but ever since i updated my sytem has been super unstabel, so where so should i send the scene file to and should i try re installing octane ?
Why don't remove 480 and try one card. I think you have HW or driver problem between two cards
toketronic
sure i will remove the 480, sorry for the bad texting running around to make a deadline
np. i'm also replying to a few guys on same time. Hard to follow each one. I bet that's a problem as i said.
toketronic
Yerh man, thanks for the great support and work on this render it kick ass ;)
toketronic
Just pulld out the 480 and now it's seens very smooth again, think i will have to get a titan more tomorrow, must be a sign :)
