OctaneRender™ for LightWave™ 2.0 DAILY BUILD
- BorisGoreta
- Contact:
Please add surface picking for instances too. Thanks !
Thanks!juanjgon wrote:I am going to review the plugin update code to try to avoid the full recompilation of the scene if it is not needed, in the IPR or in the "update scene" mode rendering. I am not sure what is possible, but I am sure that there is room to improve it.hdace wrote: There must be a way to optimize this process.
Vote for Juanjo!
juanjgon wrote:Yes, the plugin can avoid the objects unseen by camera in the picking process. I will add this feature for the next release.MrFurious wrote:Juanjo is it possible to make it so that unseen items do not interfere with surface picking via IPR? for example I often have wall sections invisible to camera (for cheating impossible camera angles with interior shots)So these invisible wall sections often are the closest item to the camera, but when set to invisible it makes surface picking impossible, as it obscures every other surfrace from IPR, even though it's 'invisible'
Thanks Juanjo that would be awesome
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
CG Artist
Melbourne Australia
I have a new test build with a complete rewritten update functions. In my testes with complex scenes with a lot of instances it is sometimes 100 times faster updating GPUs while rendering sequences in "update" mode. But perhaps something is broken ... we should test this build carefully:BorisGoreta wrote:I have a request too. Some scenes with lots of instances of "heavier" objects have long updating scene in GPU phase, when rendering sequences sometimes this phase is as long as rendering phase. (30 seconds each ) This is a waste of time in animations where only camera is moving and instances are always the same. There should be some kind of a switch which would tell Octane to process instances only once at the beginning and update only camera on all subsequent frames.
https://www.dropbox.com/s/osqqvc7njsfja ... 1_6.p?dl=0
There is a new code analyzing the scene changes that perhaps could break some kind of animations. And I need to test the network rendering to know how the render nodes are updating the scenes.
Let me know how it works with your heavier scenes, or your scenes with a lot of instances.
Juanjo, you haven't commented on my detailed post about my idea that you asked for, it's here:
http://render.otoy.com/forum/viewtopic. ... 80#p204782
I'm afraid you have just been too busy with this instance/large scene problem which of course is more important, no doubt. But just in case you didn't notice my reply, it is there
Somebody said it is impossible in polygon-based renderers but Octane and its LW plugin do many things that I didn't think was possible so I'm still hoping until you say it is not possible
Thank you very much and sorry for me being impatient
Antti
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
Yes, sorry ... I was thinking about your problem. Really I don't know a way to get this effect in Octane from the renderer point of view, but perhaps could be possible with the right displacement/opacity maps.atnreg wrote:Juanjo, you haven't commented on my detailed post about my idea that you asked for, it's here:
Antti
The idea is to have a displacement map with 0 displacement in the outside of the leaf (black, if you are using a displacement without shift), and an opacity map with the border expanded 1 or 2 pixels over the the border of the displacement. With this opacity map a little bigger than the displacement map, you could render a closed border in your object ... perhaps with little artifacts, but the render could be fine.
Would it also work if items are set to 100% Dissolve?juanjgon wrote:Yes, the plugin can avoid the objects unseen by camera in the picking process. I will add this feature for the next release.MrFurious wrote:Juanjo is it possible to make it so that unseen items do not interfere with surface picking via IPR? for example I often have wall sections invisible to camera (for cheating impossible camera angles with interior shots)So these invisible wall sections often are the closest item to the camera, but when set to invisible it makes surface picking impossible, as it obscures every other surfrace from IPR, even though it's 'invisible'
Dino Inglese
CG Artist
Melbourne Australia
CG Artist
Melbourne Australia
Ok, that I was afraid of but now I believe it is impossible so I won't dream about it anymorejuanjgon wrote: Yes, sorry ... I was thinking about your problem. Really I don't know a way to get this effect in Octane from the renderer point of view,
WOW that sounds like a great idea! It could actually work, of course making such opacity map is quite a job but maybe it can even be made with ImageMagick so it could be automated.juanjgon wrote: but perhaps could be possible with the right displacement/opacity maps.
I will look into this, thank you very much!
I was explaining to my partner what an 'Uber Developer' means.. hope you don't mind using you as an example.juanjgon wrote:DoneMrFurious wrote: Would it also work if items are set to 100% Dissolve?
Thanks heaps Juanjo looking forward to the next release.
Dino Inglese
CG Artist
Melbourne Australia
CG Artist
Melbourne Australia
