smooth and Rounded Edges problem
denver2
I have a problem with the geometry of the standard Poser figures
example with figure OliviaG2
http://joxi.ru/vR8hVP3JTJA-XYwQ0tw
example with figure Roxi
http://joxi.ru/ICEhVIwyTJDLAsqqB4Q
denver2
many artifacts in the shadows . edge of shadows very hard. The feeling that the figure turned into a little polygon
Hi - I just tested this and you are right - shadow artifacts are being creating. To get around this, either use the "texture environment" (rather than Daylight), OR set the subdivision level of the mesh to 1. I will report this to Otoy.
denver2
Thank you! When will the cure from Otoy ?
I'm not sure - sorry. Just set subd to 1 to get around this - or use texture environment lighting.
denver2
Hi -set the subdivision level of the mesh to 1 - DOES NOT SOLVE THE PROBLEM!
Function - Daylight works with glitches in most cases
I think,
if the plugin works on half,
Otoy must return money (half of the wholesale prices) this product!
Zay
Adjusting the rayepsilon in the kernel settings should fix the shadow problem.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
denver2
Zay wrote:Adjusting the rayepsilon in the kernel settings should fix the shadow problem.
No,
I already gave examples and can give many more
kernel settings - DOES NOT SOLVE THE PROBLEM!
Zay
It's a problem Octane have had since day one. To fix it you need to resize your scene. I always resize to decameters and set rayepsilon until the eyeshadows go away and the mesh shadow problem goes away. If it doesn't you need to scale the scene even more.
Below is Roxy, at subd 1 (in the Octane settings), with sun size 2, and ray epsilon 0.00001. I don't see any artifacts.
Also - as Zay rightly says, you can rescale the scene in the Configuration settings to get around this.
Return to “Poser”
