Titan and GTX480
toketronic
Hey Guys - Is it possible to run this a Titan and GTX 480 cards together in one machine and how do i set up if possible ?
Best
Toke
glimpse
if You have enough PCIe slots & power to feed these two beasts I see no problem running them together. Just plug Your monitor into Titan =) so it would not eat somewhat 300mb of Your vram from smaller card =)
enigmasi
use 480 for screen, use titan at full power
glimpse
that's probably the best idea, if You don't have a 4k Monitor (as You could not plug it into 480 =)
toketronic
Thanks guys i do have a pretty big monitor http://www.lg.com/us/monitors/lg-34UM95 ... de-monitor
so would that still be the best idea ?
whersmy
How does the gtx 480 perform against the Titan?
My guess would be about 50% slower?
Greets
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
toketronic
Hmmm could you compare it like this, i'm not sure
Gtx 480
GPU Engine Specs:
CUDA Cores 448
Graphics Clock (MHz) 607 MHz
Processor Clock (MHz) 1215 MHz
Texture Fill Rate (billion/sec) 34.0
Memory Specs:
Memory Clock (MHz) 1674
Standard Memory Config 1280 MB DDR3/GDDR5
Memory Interface Width 320-bit
Memory Bandwidth (GB/sec) 133.9
Titan
GTX TITAN BLACK GPU ENGINE SPECS:
CUDA Cores 2880
Base Clock (MHz) 889
Boost Clock (MHz) 980
Texture Fill Rate (billion/sec) 199.1
GTX TITAN BLACK MEMORY SPECS:
Memory Speed 7.0 Gbps
Standard Memory Config 6144 MB
Memory Interface GDDR5
Memory Interface Width 384-bit
Memory Bandwidth (GB/sec) 336
toketronic
but will find out later today when i get it hookt up :)
glimpse
You can't hook up that monitor on 480 I believe from sight at specifications on nvidias site =).. so You're left to plug monitor into Your TitanBlack. Just remember if You're going to render with both cards You'll get better render times, but lower maximum available gram, as scene should fit into both cards (& You're limited by smallest amount of gram, that sits on Your 480). So if You get some problems that scenes don't fit simply disable 480 & do all the work on TitanB.
toketronic
Thanks alot, will se how it's going or i will disable the GTX480
