Urgent! Render failure
everything
Hi!
Im trying to render an scene and I'm getting the render failure message:
"Please check Octane Render Log Window from
Settings->Other->Show Render Log button..."
I have no problems with preview window render. It works fine but when i try to send it to the "Render To Picture viewer" i get the above message.
The logs say the following:
Export materials time= 90.356 ms
Collect objects time= 6.623 ms
Meshes creation time = 6604.218 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 621.496 ms
SIZE 1400 1024 RATIO:0.1 NEWSAMPLES:102
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
-> failed to allocated device memory
device 0: failed to upload data texture 1 of context 0
<<< Render Failure >>>
Total export Time = 423791.412 ms
************ VP RENDER FINISHED **************
Im desperate and my client is really mad with the delay. Any solution?
Thanks!!
Mac Pro 5,1 (Mid 2010) / 2 x 2,66 GHz 6-Core Intel Xeon / Nvidia GTX 780 6GB + GTX TITAN X 12GB / 24GB RAM / OS X 10.10.2 / C4D R16 / Octane Standalone 2.22 / OctaneC4D 2.21.1
www.everything.is
It's hard to say something without knowing your scene content. Live Viewer uses viewport data to render. But Picture viewer uses render data. Even for objects. There is a memory error as:
"CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation."
Last note: What's your render resolution? I think it's much bigger than LV buffer's?
everything
hi! Thanks so much for helping :)
well the render resolution is 1400x 1024. 72dpi. nothing fancy.
The project itself is like this below
https://www.dropbox.com/s/kg9ynaokliovz ... 4.png?dl=0
My graphic card is a gtx680
Is there any sollution?
Thanks so much again
www.everything.is
i could get much info sorry. My advice to you try to close some objects or delete some materials to find what causes error.
