RedSpec TGX Wet Beta
TRRazor please check your PM. Thanks.
Windows 10 64bit | 2 x NVIDIA TITAN XP 12GB | Intel i7-6900K (8 core/16 thread) | 64Gb RAM | GeForce Driver 376.33 | PoserPro Game Dev 2014 SR4, 10.0.5.28925 | Poser Octane Plugin Version: 3.4.4.79 | HDR Light Studio 4.3.20131206.1249, Poser v1.0.3
Cool.. lets use this place for a greet and meet... here's my PM and oh... look... there's another...
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RAM: 64GB
Rgus... lets start a good conversation... what shall we talk about
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
So I bought the wet maps a few days ago and tried them. When I try to load them I get the following message:
Octane error: File Load Error: Could not load 'C:\Program Files (x86)\RedSpecTGX\redspec_tgx_b_replace.jpg:rgba'.
Then I get that same message again 17 more times sometimes with mono instead of rgba. Did I get a bum download? I'm doing the normal retain existing image maps like I do with normal TGX which don't have this issue. I get this message on all 3 of the poc files. This is with 2.6.0.23 of the plugin.
Hey Pandarr,
thanks for reporting this problem.
It is most likely caused by a problem with the installer.
Would you please copy the file folder from C:\Program Files\RedSpecTGX to C:\Program Files (x86).
You should afterwards have two folders with the name "RedSpecTGX" and the same content sitting in both folders.
Sorry for the inconvenience this might have caused, I'll look into the problem once I'm home from work today and will update the customers with an updated version of the shaders where this problem should not longer be present.
Please let me know if the problem remains after you tried the a.m. solution, since I'd recommend solving the problem through Skype if it persists.
Thanks again
Thanks again
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Yep. I see a RedSpecTGX folder in Program Files but nothing in Program Files (x86). The .poc of course is looking for it all in (x86) so that's the issue. So the installer will either need to install in (x86) or the POC files updated to reflect being in the non-(x86) folder.
