The next (draft) version of the Modo OSX plugin can be downloaded from
http://render.otoy.com/customerdownload ... MacOSX.pkg. There is an outstanding issue where you may find your GPU's UNselected in the Cuda tab of the plugin. If so, re-enable them. The release notes for this version are:
2.6.0.25
- Compiled gainst Octane 2.06
- Added GI Clamp in the Kernel settings
- If the Modo environment map has been mirrored (ie. the texture locator Horizontal Wrap = -1), the Octane envirnment will also be mirrored
- Fixed performance issue when exporting an amination to ABC ORBX/OCS
- IMPORTANT: when using "octane.command exportAlembic", export to OCS format if possible, since that uses much less disk space (because the ABC file does not need to be stored inside the ORBX container)
- "octane.command exportAlembic" now only exports the following animated Octane camera node pins: pos, target, up, fov, focalDepth. So aperture is not animated (let me know if you need it animated)
- "octane.command exportAlembic" now no longer stores the camera animation in the ABC file - it instead stores it in the Octane Camera node of th ORBX/OCS file
- Added potential fix for the minor lag issue when navigation the Modo preview window when the plugin Setup window is open
* KNOWN ISSUE: Running out of disk space during the "octane.command exportAlembic" process will crash Modo. This has been reported to Otoy.
