350 to 450 watts per card. Over 1200 watts total.
I can't imagine rendering animations overnight without a big elec bill the next month.
http://www.anandtech.com/show/4008/nvid ... gtx-580/17
http://www.anandtech.com/show/6774/nvid ... nveiled/15
hey, Lewis what temps are You getting??? still on air? =)Lewis wrote:22 seconds using 3*Asus STRIX OC 780GTX 6Gb clocked to 1200Mhz
Yes still fine. A s matter of fact I've added 4th GPu (760GTX 4GB) just for windows image (so that all STRIX are free of display) and temps for STRIX cards are from 65-75 depends where is card positioned. I can't go to water-cooled version anyway since vendors don't have water block for STRIX cards yet (different PCB). The one sitting in vertically (custom made holder) is coolest and middle one is hottest.glimpse wrote:hey, Lewis what temps are You getting??? still on air? =)Lewis wrote:22 seconds using 3*Asus STRIX OC 780GTX 6Gb clocked to 1200Mhz
Doesn't the gtx 580 have 1.5 gig mem?MrFurious wrote:Surprising the small difference between the Titan and the GXT580. Load temps the same and load consumption more on a titan? Doesn't look right to me, I'm sure from my research the Titans were supposed to be cooler & more power efficient than the Fermi cards 580, 590 etc? I'm not poo-pooing that review it just looks odd
Somethign is not right there, 750Ti in full load is aroudn 60-65W not 35.geo_n wrote: I measured my palit 750 ti at 35 watts with a power meter.
Seems to be dependent on the scene being rendered. My I7 3770 is 60 watts on idle measured at the outlet. When I render the benchmark scene it reaches 90-95 watts. I then rendered the instancing scene sample and it was 100-105 watts. So around 35-45 watts according to my watt meter.Lewis wrote:Somethign is not right there, 750Ti in full load is aroudn 60-65W not 35.geo_n wrote: I measured my palit 750 ti at 35 watts with a power meter.
http://www.tomshardware.com/reviews/gef ... 50-21.html
Not really, check the graph more closely at first page it says "VGA Card ONLY". And if you look it logically it's impossible that whole machine uses 6W and 9W at idle (first two graphs) when connected single and multimonitors so yes that's measurments for VGA card alone not complete system (speakign abotu FIRST page graphs).gristle wrote:Note the Anandtech power graphs are overall system power, not just card. So kjnock some watts off for CPU etc.
