Octane Materials. Questions thread.
- linvanchene
edited and removed by user
For a three card setup I would plug my monitors into one card and use the other two for rendering. As Tugpsx suggests I would Activate one card at a time to determine which one the monitors are plugged into. Then deactivate the one you are using for the monitors and activate the other two without priority.
If you want to use all three then enable priority only on the monitors card but you will loose some memory if you do.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
linvanchene and Orion_UK
Thanks. Texture Emission. Forgot about that (bit rusty having taken a break from Octane for a month or two before the Carrara release).
Changing the scene parms to up the lighting to compensate, that's a good idea linvanchene thank you.
Here is a TV Screen test
Could not agree more, nice one TugSciFiFunk wrote:Excellent effect on the screen it's self Tugs.
Also, imagine how much better this would be when Sighman adds animated PNG sequences ( a recent request of mine) ..
That would (if possible) bring the screen to life even more
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
A big thank you to you all for sharing more info regarding multiple cards, Glad I did have things hooked up as I 'should' have
Also, thanks for the tips on determining which of my cards in the list is using which monitor, I will check this out when I get home tonight
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
Thanks guys, I have to finish my animated texture script for standalone. I haven't worked on it in a while.
Playing with more textures Octane Grass.
Ohh, like the sound of thatThanks guys, I have to finish my animated texture script for standalone. I haven't worked on it in a while.
The grass is coming along great Tug, keep it up matePlaying with more textures Octane Grass.
Here is a quick test with PySwarm..
http://render.otoy.com/forum/viewtopic.php?f=79&t=42152
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
