Displacement slot
Moderator: JimStar
prodviz
Hi Jim,
I'm finding that when I click and slide in the displacement slot, the value can easily jump to a very large number, which then freezes maya.
Is there a way to make this a little less sensitive?
cheers,
Steve
Wenneker
Some of the sliders in Octane are setup in a logarithmic scale in the standalone but I don't think maya supports this. My preference would be to have the sensitive sliders to have a default range that is much smaller than the are now, for default from 0-1 instead of 0-1000 but with the ability to extend them by typing in a higher number.
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
prodviz
Just testing now, and if I slide the height value, I get 78295055048641139756937439080148369408.000 for example.
Agree, a slider value of 1000, or maybe even 10 as a cap, with the option to 'type' in any value.
itsallgoode9
yep, there are some other sliders i've run into that do the some thing. it's a little rough when you want to set something to 5 and you end up with a 10 figure number just because you used the slider.
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
Return to “Autodesk Maya”
