ies files
- billyjoe2014
Hi, was just wondering where I could connect ies info. Do I use black body for emission type? and where do I connect it? The choices are efficiency or texture. The same choices for texture emission. On the drop down lists for either none seem to be ies related. For black body, there is the entry for temperature, I know I would like in this case to use halogen lights and their temperature is 3200k but that wouldn't give the shape of light which I think is contained in the ies files.
The online manual has some nice info about the usage of mesh emitters, it can be found here:
http://render.otoy.com/manuals/Standalone/?page_id=390
or here:
http://render.otoy.com/manuals/Poser/?page_id=104
Personally, I too, use the "Distribution" slot for IES maps, as it's suggested in the manual.
or here:
I always use the distribution node for IES files. That makes sense since the IES files define the range and fall off of the light. Make sure that you have set the position type to Normal Space (in the projection mode of the distribution map).billyjoe2014 wrote:Hi, was just wondering where I could connect ies info. Do I use black body for emission type? and where do I connect it? The choices are efficiency or texture. The same choices for texture emission. On the drop down lists for either none seem to be ies related. For black body, there is the entry for temperature, I know I would like in this case to use halogen lights and their temperature is 3200k but that wouldn't give the shape of light which I think is contained in the ies files.
If you do this, the light faces into the direction of the normals making it easier to direct or point the light
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
- billyjoe2014
Thanks very much for your help, its much appreciated.
