Octane exporter for C4D version 0.12b (current)
ingostan
Hi Again
Is a new exporter in work?
Alul
abstrax wrote:
shibinss wrote:how about c4d R15 version ?? possible ?
I don't have a r15 unfortunately, but does the R12 build version not work in R15? I can make a R14 build, but I don't know if that helps.
Hi. Exporter is not working in R15 for me.
Can you please check this out if I did something wrong. I'm in the middle of XSI>C4D switch so i can make mistakes
TonyBoy
How does Exporter 12B (for 11.5 or 12) work for Standalone 2.0?
b1siu
Hi ;)
Is Octane Exporter 12-14 works with version R16?
https://www.facebook.com/vrayenginestudio
http://www.vrayenginestudio.com
Intel i7 4930K - Corsair H100i - GTX 780 Ti OC - 32GB Ram - SDD 180GB - 2x Dell U2414H
augdalmo
yes it works fine.
Nevertheless I have encountered the same limitation as in R15, the exported material will lose the link of the texture so you must recreate the material in Standalone, very boring and time consuming if the scene has several materials. I hope that Octane Render Team will correct this problem soon
abstrax
augdalmo wrote:yes it works fine.
What exactly is the problem?
Just for your information: I didn't have time to work on the plugin for ages and if you want the real deal, you should use Ahmet's Octane for C4D plugin (http://render.otoy.com/forum/viewtopic.php?f=30&t=42257 and http://render.otoy.com/forum/viewtopic.php?f=30&t=42607).
augdalmo
I refer to Octane Export plug in not to Octane render plugin for C4D.
As you create a material in C4D with the plugin of Octane Render for C4d and export to render on Octane Standalone with the OctaneExport plugin the link to the texture images of the materials will be lost, as you can see on the screen shots attached.
"Collect all texture images" doesn't works.
material output on Standalone
material created in C4D
window of Octane Export - "Collect all Texture Images" is selected
abstrax
augdalmo wrote:I refer to Octane Export plug in not to Octane render plugin for C4D.
Yes it works but only with very simple materials and only when they are the standard C4D materials. That's mostly because OBJ/MTL doesn't allow any fancy materials and because the materials of the C4D Octane plugin are not documented and subject to change (and at the time I wrote the export plugin the Octance for C4D plugin didn't even exist).
But since you are already using the C4D plugin you can use the plugin to export the scene to Octane Standalone using the Octane Dialog and selecting File -> Save Ocs.
augdalmo
many thanks for your support!
César
Hello,
I just see that the new Octane version support multiple UV. Will you update this exporter to manage this feature ? I know that OBJ don't support it but you spoke about some possible tricks :
Octane tries to look for data that looks like additional UV sets in Alembic files and the plugins will have the possibility to export them, too, via the Octane API, but for now it's kinda tricky to use this feature if the source geometry doesn't supply multiple UV coordinates.
I am still more confortable with the standalone. I hope that it will be still possible to use it with multiple UV.
